How to Fill in Chasing Left by Electrician
Skythepig
by Skythepig » Mon Jul 31, 2023 11:55 am
Hi after water damage which is now dried out, we have an electrician coming to replace some sockets and back boxes which will involve chasing out some of the wall.
I was hoping to patch the chasing myself and wondered what would be recommended.
It is not going to be a lot, just 3 short runs, so is there any ready mixed rough base coat and finish plaster I can buy rather than large bags of plaster etc.
Wall construction is old stone, looks like sand and cement render, then finish plaster. TIA
Re: How to Fill in Chasing Left by Electrician
by stoneyboy » Wed Aug 02, 2023 9:49 pm
Hi skythepig,
Since you already have a sand and cement render use the same material for the base coat but wet the chasing before you make good. You can then finish off with plaster.
Skythepig
by Skythepig » Fri Aug 04, 2023 11:16 am
Do i need to wet it with a PVA mixed with water?
by stoneyboy » Fri Aug 04, 2023 9:34 pm
Hi skythepig,
No just damp down the chasing so water is not sucked out of your mortar render.
It is currently Sun Nov 24, 2024 3:15 am
