Replacing Light Fitting
jamesxmx
by jamesxmx » Sun Oct 14, 2007 2:48 pm
Removed Ceiling rose as per instruction
New light has a 4 way terminal block with light wired to block as Live , Neutral, Earth , Spare.
There are 2 cables from ceiling , one the Mains , other is switch - both standard 3 core.
I wired the mains cable to the terminal block, matching Live , Neutral, Earth
When I wire the cable from switch on same matching , it blows fuse.
Advice would be apprecaited.
James
BLAKEY1963
Re: Replacing Light Fitting
by BLAKEY1963 » Sun Oct 14, 2007 6:37 pm
[quote="jamesxmx"]Removed Ceiling rose as per instruction
Jice would be apprecaited.
James[/quote]
JAMES XMX
SOUNDS LIKE LIVE AND NEUTRAL DEAD SHORT ACROSS
SWITCH , BUT NEED MORE INFO ?
HAVE U LOOKED AT DOC S PROJECT SECTION ON LIGHTING.
HAVE U GOT 2 RED AND BLACK CABLES ?
BLAKEY1963
It is currently Tue Jan 14, 2025 12:11 pm
