Measure thickness of self-leveling compound
jradxl
by jradxl » Sat Aug 19, 2023 12:17 am
There's loads of videos on how to lay self-leveling compound, but none I've found tell or show how one knows what thickness has been achieved.
Is it a matter of just vertical sticking a steel rule in the stuff in about three places and adding more stuff if it's still too thin?
Re: Measure thickness of self-leveling compound
by stoneyboy » Sat Aug 19, 2023 10:12 pm
Hi jradxl,
If you are using self levelling compound it’s probably to cure uneven floor levels so measuring thickness would be meaningless. Lay the compound so it gives you a level surface, thickness doesn’t matter most can be applied feather edge up to 10mm.
It is currently Wed Dec 04, 2024 8:54 am
