Patio door eurolock out
Conservatories are a great all-round addition to any home. Find help, advice and information on all aspects of this area.
Pommeinzennor
by Pommeinzennor » Sun Sep 24, 2023 3:41 pm
Hello,
I have just moved house and it has a conservatory door eurolock which was just spinning. I have removed the lock but can’t unlock with an Allen key.
This is what I see from the inside
Inside
Inside
and outside
Outside
Outside
Anyone know how to get the door open?
Many thanks for the help.
Re: Patio door eurolock out
by stoneyboy » Tue Sep 26, 2023 9:26 pm
Hi pommienzennor,
With the cylinder out of the lock, when you turn the key does the cylinder cam rotate as the key is turned.
If you can and you cannot stop the cam turning with the key you will need to investigate the lock mechanism.
If the cam does not turn with the key you need a new eurocylinder_
It is currently Sat Jan 04, 2025 10:25 pm
