Which to chose: Knauf XPS Laminate Plus Insulated Plasterboard 27mm or Celotex PL4000 Insulated Plasterboard 37.5mm
John89
by John89 » Wed Oct 18, 2023 9:56 am
Hi all,
A kids' bedroom is really cold. Two cavity walls with no insultation.
I am considering insulating it from inside with the insulated plasterboard.
Which one to chose: Knauf XPS Laminate Plus Insulated Plasterboard 27mm or Celotex PL4000 Insulated Plasterboard 37.5mm:
1) Which one gives better heat insulation?
2) Can both be installed using Plasterboard Adhesive Foam?
Thank for your advice.
Re: Which to chose: Knauf XPS Laminate Plus Insulated Plasterboard 27mm or Celotex PL4000 Insulated Plasterboard 37.5mm
by stoneyboy » Thu Oct 19, 2023 12:00 am
Hi john89,
The Knauf insulation material has a lambda value of 0.03.
The Celotex insulation material has a lambda value of 0.022 so you are better off with the celotex.
It is currently Wed Dec 04, 2024 8:31 am
