Couple of radiators in my house are 1970s whereas the rest are modern. The pin on the TRV gets stuck in and last year i had to lube them up to get them to pop out. It worked and the radiators worked great.
This year the same i have lubed them up and the TRV pins are all good
However neither radiator is hot
Valves are open and tried bleeding but just water came out
The pipes leading to the radiators (which are in different rooms) both feel cold even after an hour of heating running
Any ideas what the issue could be here?
thanks
