Mahogany furniture board has vanished.
sydh
by sydh » Thu Dec 07, 2023 5:30 pm
I have some mahogany bookcases, similar to the attached photo, which I wish to add to but dark mahogany seems to have gone out of fashion and apart from some examples in excess of several hundred pounds, there is only Ebay as a possibility.
The alternative is for me to make my own, but even mahogany faced MDF or chipboard has disappeared. I am considering using 19mm ply but then the problem is trying to stain and varnish the wood to the correct shade and finish.
So 2 questions:
Has anyone seen any dark mahogany faced material anywhere, preferably 300mm wide?
Can anyone advise on the best method to turn plywood into dark mahogany?
Re: Mahogany furniture board has vanished.
by stoneyboy » Sat Dec 09, 2023 10:41 pm
Hi sydh,
The company that does it all sells oak faced furniture board but you would have to stain it so it looks like mahogany.
sydh
by sydh » Sun Dec 10, 2023 10:28 am
Thanks but which company?
by stoneyboy » Sun Dec 10, 2023 9:57 pm
B&Q
sydh
by sydh » Sat Dec 16, 2023 12:02 pm
Had a look at it but not sure if it is veneer. Could be melamine or whatever is it they use. If I'm doing staining I might as well use high grade ply. Still a lot more work than sourcing mahogany faced wood. Will probably just have to keep searching Ebay for bookcases. Thanks anyway.
It is currently Sun Nov 24, 2024 2:04 pm
