Wiring an outdor light
zubrant
by zubrant » Mon Oct 15, 2007 2:29 pm
I'm not a great DIYer by any means and have just removed an old outdoor light by the doorway. Behind this are two cables, each with a red, blank and earth.
I have a new light which has a brown, blue and earth.
I have tried several connections but cannot get this to work when I flick the switch - can anyone give me a hand please?
Once combination made the light come on but I could not turn it off.
BLAKEY1963
Re: Wiring an outdor light
by BLAKEY1963 » Tue Oct 16, 2007 10:19 am
[quote="zubrant"]Hi,
Cheers[/quote]
ZUBRANT
QUITE POSSIBLE THAT ONE OF THE BLACKS WOULD HAVE BEEN TAGGED RED AND MARKED AS A LIVE SWITCH WIRE.
THIS WOULD GO TO BROWN ON FITTING.
YOUR OTHER BLACK UMARKED WOULD B A NEUTRAL AND GO INTO
THE BLUE WIRE OF THE FITTING.
TWO REMAINING REDS ARE PERMANENT LIVES AND R CONNECTED
TOGETHER IN A BLOCK , TAPED UP.
THE TWO BARE EARTH CABLES , WHICH SHOULD B SLEEVED IN GREEN AND YELLOW SLEEVING. ARE CONNECTED TO THE EARTH WIRE OF FITTING. ( MOST IMPORTANT !!!!!!!!!!!!!!!! ).
BUT THIS WORKS IS OUTDOORS AND BECAUSE A SPEACIAL LOCATION
OF INCREASED SHOCK RISK COMES UNDER PART P AND IS NOT DIY.
I WOULD ADVISE GETTING IN YOUR PART P SPARKY
TO HELP U .
It is currently Tue Jan 14, 2025 12:33 pm
