Toilet seat replacement - help needed!
RobinL99
by RobinL99 » Thu Feb 01, 2024 1:19 pm
Hey everyone,
Moved into a new flat and wanted to replace the toilet seat.
I've removed it, but naively ordered a new one that doesn't quite fit. I therefore need to a) identify one that does fit or b) remove the chrome fixtures so I can replace with an adjustable seat (for example https://www.amazon.co.uk/MUJIUSHI-Relea ... 324&sr=8-5).
The latter seems like the easier / cheaper option, HOWEVER I am having real trouble removing the chrome fixtures. Unscrewing them just seems to rotate them without them loosening, and I've tried prising the chrome caps with a chisel / hammer with no luck. There's no access from below either...
I've been struggling with this for a little while now - any help greatly appreciated!!! Pictures below, thank you!
https://imgur.com/DrCW4O4
https://imgur.com/lu0FUBn
https://imgur.com/tJpAMSO
Re: Toilet seat replacement - help needed!
by stoneyboy » Thu Feb 01, 2024 10:15 pm
Hi robinl99,
Some fixings are like cavity wall toggle fixings, once they have been in place for a while they rust. You could try levering upwards under the collar and unscrewing at the same time. If this is unsuccessful cutting the fixings may be the only solution.
It is currently Mon Dec 02, 2024 11:31 am
