Am I able to cover up a cracked internal window sill?
jonlondone17
by jonlondone17 » Sat Apr 13, 2024 2:49 pm
Hi everyone
I have a PVC window sill in the front room which is hollow inside and has become cracked along the top surface as per the attached photograph.
I'd like to cover this rather than tear it out and replace it, and I've seen products for this purpose available from companies such as Eurocell.
However, the window sill narrows in the centre where the wall is, and then goes back to it's normal size after the wall (as per the second photograph). Therefore, I don't think the Eurocell product would work in this case. Each "long" part of the cill is roughly 40” long x 4” deep with a 9” centre piece where the wall is (101.6cm x 10.16cm with 22.86cm centre piece)
Could anyone provide me with any help or ideas on how I can achieve my aims, or point me in the right direction of any relevent products?
Many thanks,
Jon
Re: Am I able to cover up a cracked internal window sill?
by stoneyboy » Sun Apr 14, 2024 10:25 pm
Hi jonlondone17,
You could buy a length of upvc capping board and fit this on top of the existing cill. You will have to do some careful cutting and the front edge will have a corner rather than a rounded edge. Use silicone mastic to hide the join and to stick the cover board down.
jonlondone17
by jonlondone17 » Thu Apr 18, 2024 9:49 am
Hi jonlondone17,
Hello Stoneyboy
Thanks so much for your reply. I'll give it a try!
Best wishes
Jon
It is currently Thu Jan 02, 2025 3:07 pm
