Fill valve won't stop nor flush - Easy to fix myself?
6 posts   •   Page 1 of 1
scotdiy86
by scotdiy86 » Mon Aug 12, 2024 3:35 pm
We have a push button toilet that has developed two issues and I'm wondering how easy it would be to do on my own with the right parts rather than calling out a plumber.
I've fixed various things in our home from a shower, oven and even our washing machine so would love to do this myself if it saves me money.
The first issue is that some plastic piece from the flush valve broke off meaning it would just keep letting water flow into the bowl unless you manually push it down.
The second issue is that the fill valve won't stop no matter how much I adjust it, it just fills up till it overflows over and into the flush valve and keeps going untill I manually switch of the flow of water to the cistern.
Thanks in advance
Re: Fill valve won't stop nor flush - Easy to fix myself?
by stoneyboy » Wed Aug 14, 2024 10:01 pm
Hi scotdiy86,
If you can identify the flush valve manufacturer and get a new valve replacing it is a matter of turning the valve and lifting it out of the mounting boss. The fill valve is best replaced.
scotdiy86
by scotdiy86 » Thu Aug 15, 2024 10:22 am
stoneyboy wrote: Hi scotdiy86,
Thanks, couldn't see a manufacturer but found a flush and fill valve set that is similar to what I had so ended up getting that.
Both are basically drop in replacements and worked just fine, although they do drip a little bit so need to double check i've tightened them enough and any seals but at least I can use my toilet for now.
by stoneyboy » Thu Aug 15, 2024 10:22 pm
Hi scotdiy86,
Thanks for updating us - if the fill valve is dripping there may be debris in the valve, if the flush valve is letting by it’s either debris in the seating or it not adjusted height wise.
scotdiy86
by scotdiy86 » Sun Aug 18, 2024 5:56 pm
Both were dripping on the outside of the cistern, small droplets of water at a time so nothing major but enough to need to sort it.
Ended up fiddling with the fill valve to ensure it was getting a proper seal and tightening a bit more than the first time which worked.
As for the flush valve, the pre-attached seal was the right size for our toilet but I cut up the extra one meant for if you had a different size hole, put it on the outside and once all tightened up it seems to have stopped any drips we had.
All now flushes just fine and fills up without issues, sure we don't get quite as much of a fill with the new valve even after adjusting it to the max, though TBH I am not too bothered and more glad it all works now.
opplumbinghub
by opplumbinghub » Thu Sep 26, 2024 8:03 am
Thanks in advance
To fix your toilet, start with the flush valve. Find the broken part, which is probably the flapper or flush valve, and get a new one from a store. Turn off the water supply and take off the tank lid. Replace the broken part according to the instructions.
For the fill valve, first try adjusting it to stop the overflow. If it still runs, take it off and check for any clogs. Clean it if it’s dirty. If it doesn’t work after that, buy a new fill valve and install it. Make sure to have tools like a screwdriver and adjustable wrench ready, and turn off the water when you’re working on it. Good luck!
It is currently Thu Dec 26, 2024 9:44 pm
