Transformer Change?
cambridgeblue
Transformer Change?
by cambridgeblue » Wed Oct 17, 2007 10:01 pm
I have ceiling lights (6) on a dimmer switch which won't turn on. I have been advised that I should change the transformer(s). Please can anyone advise how to go about this?
Thanks.
BLAKEY1963
Re: Transformer Change?
by BLAKEY1963 » Thu Oct 18, 2007 9:38 am
[quote="cambridgeblue"]Hi,
Thanks.[/quote]
CAMBRIDGEBLUE.
ISOLATE SUPPLY.
THEN U COULD REMOVE TRANSFORMER AND MATCH IT
AT WHOLESALERS TO CHECK U HAVE THE CORRECT
RATED AND TYPE OF DIMMER.
IF MATCHED THEN OUTPUT OF TRANSFORMER WOULD NEED TO BE VERIFIED.
BLAKEY1963
cambridgeblue
by cambridgeblue » Thu Oct 18, 2007 6:13 pm
Thanks Blakey.
Exactly how do I remove the transformer?
cambridgeblue
by cambridgeblue » Thu Oct 18, 2007 6:15 pm
Thanks Blakey,
Exactly how do I remove/change the transformer?
BLAKEY1963
by BLAKEY1963 » Fri Oct 19, 2007 12:42 am
[quote="cambridgeblue"]Thanks Blakey,
Exactly how do I remove/change the transformer?[/quote]
Cambridgeblue
If the transformer is a independant unit then disconnect
cables noting mains in and mains out connections.
u will have isolated main supply before doing the disconnecting.
if the tranformer is riveted and can t be disconnected solely then the lighting module unit /unit could be taken in to whole saler.
BLAKEY1963
It is currently Tue Jan 14, 2025 11:55 am
