changing power shower to thermostatic one
ghostridet
by ghostridet » Fri Sep 27, 2024 12:42 pm
Hi, we need to replace an old Mira 100 Supajet power shower with either a thermostatic or electric one. It seems that the old shower had a separate power unit, it has two switches on the outside of bathroom wall; we've got a new oil combi boiler and the old shower is not compatible. Is it possible to replace it preferably with a new thermostatic one without having to rip the walls of the bathroom open?
Re: changing power shower to thermostatic one
by Mr White » Fri Sep 27, 2024 2:51 pm
It would depend on where the pipes that supply your current shower are as to if you would have to "rip the wall out" to fit a new shower.
As for an electric shower you would need to have a large (10mm cable) installed as a good electric shower uses 10 KWatts (More than 3 electric kettles at the same time)
Why not ask who ever is installing your boiler what they suggest, after all they are there and can see what you have. I would only suggest electric shower as a last resort/back up. The shower itself is not that bad to buy, (Less than £200) but they cost a lot to run.
It is currently Thu Dec 26, 2024 9:52 am
