Wallpapering
elainemanning
Wallpapering
by elainemanning » Thu Oct 18, 2007 11:47 am
Can you wallpaper straight on to new plastered walls or do the walls need to be treated first
Ken Woodchef
Papering on new Plaster
by Ken Woodchef » Sat Oct 20, 2007 1:43 pm
Hi, new plaster can be quite thirsty, so it is probably worth 'sizing' the walls with a weak wallpaper mix first and letting this dry off for a while, this will help when papering by not drawing too much moisture out of the pasted paper and allow easy 'sliding' of the paper to align it up.
There are proprietary plaster sealers you could use, but sizing should do the trick.
Good luck
Ken
thedoctor
by thedoctor » Sat Oct 20, 2007 8:07 pm
See our projects section its all in there.
rosebery
by rosebery » Thu Oct 25, 2007 6:17 pm
How new?
Bonding and finishing coats or plasterboard and skim?
If the former it's AT LEAST 6 weeks drying out if the latter you can work on it inside 24/48 hours.
Always size plaster walls before papering. Don't use PVA!!!
gizmo
Why not use PVA to size newly plastered walls?
by gizmo » Tue Jan 22, 2008 2:32 pm
Hi, just read a post which said not to use PVA to size a newly plastered wall prior to papering. We've always used watered down PVA, why is this not a good idea? Thanks.
It is currently Fri Nov 22, 2024 9:37 pm
