Multiple spotlight installation
mauler
by mauler » Sun Oct 28, 2007 12:25 pm
I am changing a strip light in my kitchen for 10X 50W GU10 Halogen downlights in a drop ceiling.
I assume I need to use a junction box in order to connect them all to the one set of wires coming out of the ceiling but I am unsure what I need to buy.
Can anyone help please.
kbrownie
by kbrownie » Sun Oct 28, 2007 4:15 pm
Hi mauler,
A couple of things to be considered, is it already being supplied by a junction box or is it on a loop? Down lights are fitted in series and are connected together running cables from one to the next and so on. If the current supply to light fitting is via a juntion box it's easy but not standard procedure anymore. If Loop in, a little more complicated.
But as this work is being done in Kitchen it will come under Part P of building regs and needs to be done by Part P qualified sparky.
Kind Regards and best of luck
KB
by sparx » Sun Oct 28, 2007 9:48 pm
I am sure your registered 'Part-p' leckie will know as doing this work in a kitchen is a building regs,'controlled service' and not legal DIY unless fees paid first to LABC,
see project partp on here,BW SPARX
It is currently Wed Jan 15, 2025 12:10 am
