Whistling Mira Excel Shower
Johnboy1
by Johnboy1 » Tue Oct 30, 2007 7:39 am
Hi All, I`ve recently moved to a house with a fitted Mira Excel, great shower but rather noisy(whistling). It does seem to quiten down when the cold tap on hand basin is running. Obviously a pressure problem. ANY IDEAS`S PLEASE.
Bay Plumbing
by Bay Plumbing » Tue Oct 30, 2007 8:22 pm
Hi johnboy,
Try turning the cold main down(usualy under kitchen sink),if that doesn't work fill your basin with water(you'll see why in a min) turn off your cold supply by the same way,take the main body off the wall using adjustable spanner with a rag between jaws to stop scratching unions,there should be fillters in the inlets,wash these in your basin (see told you),and reverse job,tell me how you get on.
Cheers Mark
It is currently Thu Dec 26, 2024 12:45 am
