Gurgling soakaway drain
ajo
by ajo » Sun Nov 11, 2007 2:27 pm
Can anyone shed light on this please....I have a rainwater soakaway drain in my garden (which has no access to the soakaway section) which takes all the rainwater from one side of the house, and recently the drain which the rainwater feeds into (the 'trap') has started to gurgle intermitently but regularly. I'm trying to figure out what is causing air to come back up the underground pipe to cause this gurgling, and how to solve the problem. Any ideas please? Many thanks.
peter the plumber
by peter the plumber » Sun Nov 18, 2007 3:35 pm
Just extend the down pipe below the water level of the drain.
It should stop it happening
toplondonchef
by toplondonchef » Sat Jan 05, 2008 7:01 pm
Hi !
i HAVE A SOAK AWAY DRAIN IN THE BACK GARDEN WHICH IS TOTALLY BLOCKED.
THIS DRAIN TAKES WATER FROM THE MAIN HOUSE ROOF AND ALSO THE GARAGE ROOF - SO A LOT OF WATER IN A DOWN POUR.
AS DRAIN IS BLOCKED, THIS CAUSES FLOODING TO THE GARDEN PATIO AREA.
ANY IDEAS ON WHAT CAN BE DONE TO CLEAR THIS SOAK AWAY - THANKS
It is currently Wed Dec 04, 2024 4:02 pm
