Process For Removing grass & Laying Paving Tiles
6 posts   •   Page 1 of 1
jokuttan
by jokuttan » Mon Apr 02, 2007 1:56 pm
I am planning to remove the grass garden and lay Paving tiles could some one help me with this process as i am totaly new to these kind of things and i want to do it myself
regards
Tony
3magnet
Removing your turf & laying paving tiles (Flagstones)
by 3magnet » Tue Apr 10, 2007 12:28 pm
1. Is your garden at a slope, or is it somewhat level?
2. What will the paved area be used for i.e pedestrian traffic or vehicle?
3. What thickness of paving tile will you be using?
4. What type of soil have you got i.e. heavy clay etc?
UKDUTYMAN
by UKDUTYMAN » Sat Apr 21, 2007 11:52 am
CONCRETE MOULDINGS
I WISH TO BUILD A PATHWAY/PATIO AREA USING MOULDINGS :?
WHAT MIX SHOULD I USE AND DRYING TIME FOR MOULDINGS
FOR USE ONLY FOR PEDESTRIAN
thedoctor
by thedoctor » Mon Apr 23, 2007 6:50 pm
Depends on the thickness but if they are 2 inches thick (50mm) and mixed at 4 to 1 allow 10 days after taking out of the mould before you lay them. Use very fine "pea" shingle for the concrete mix to get enough strength.
thedoctor
Removing grass and laying paving stones
by thedoctor » Mon Apr 23, 2007 7:31 pm
Remove grass and any soft soil Tony. See our project on building a driveway or path to get information regarding a sub base for under your patio. Then lay the paving slabs on a bed of sharp sand and cement mixed at 8 to 1. The mix should contain enough water to stay in one lump when you squeeze some with your hand but not drip any water out. This mix gives it some flexibility. The slabs should be laid so the slope is away from the hose and the top of the slabs should at no point be any higher than 150mm below the damp proof course.
jokuttan
Re: Removing your turf & laying paving tiles (Flagstones
by jokuttan » Sun Jun 03, 2007 10:05 am
[quote="3magnet"]1. Is your garden at a slope, or is it somewhat level?
4. What type of soil have you got i.e. heavy clay etc?[/quote]
Hi 3 Magnet
Sorry for a delay
The land is straight
area will be used for pedestrians and possibly for vehicle
i have no idea about the thickness of the blocks / tiles
soil is hard not clay.
It is currently Mon Nov 25, 2024 6:05 pm
