emulsioning over wood
berniesmith
by berniesmith » Sun Nov 18, 2007 3:00 pm
I am repainting a room that has a dado rail half way up the wall. Instead of removing it, I want to emulsion the whole wall. Will emulsion paint stay on the wood, if I sand it down first?
brick_dust_barbie
by brick_dust_barbie » Tue Nov 20, 2007 4:47 pm
I'd sand it down and use a primer as well. Have you considered using gloss paint instead, or do you prefer the finish of emulsion?
canny
by canny » Tue Nov 20, 2007 9:33 pm
Once you have painted it, is worth painting wih a clear matt of satin varnish as it will scuff more than the walls :D
It is currently Fri Nov 22, 2024 9:16 pm
