Tiling over under floor heating
mfw
by mfw » Tue Nov 20, 2007 6:50 pm
I'm going to lay under floor heating (electric) in my kitchen, which will be stuck on top of insulation boards.
When i come to tile, ive been advised to use Rapid Set, do I simply mix then pour the rapid set up to the height of the electric cables and place my tiles on top!
bobplum
by bobplum » Wed Nov 21, 2007 7:38 pm
if you are using rapid set you will not be able to pour it it will have to applied by trowel
most tilers would apply the adhesive to the tile then lay the tile down,that way you dont catch the heating element use a 6mm floor trowel
It is currently Sun Dec 22, 2024 2:02 pm
