I am proposing to construct an outbuilding/workshop with a single leaf block wall construction. Is it possible to use lightweight 100mm blocks for the walls - 3.7m long x 2m high? One source has suggested the wall will be too thin. I am not convinced. The roof will be constructed of timber rafters and lightweight sheet cladding.
Advice welcomed. Thank you
Malcolm
