Lifting floor boards
Lawrence
by Lawrence » Mon Nov 26, 2007 4:32 pm
I need to lift some floor boards - 22mm chipboard T&G 8' x 2'.
Does anyone have some advice on the best way to lift and replace these type of boards?
Is is best practice to cut through the boards (using a circular saw) along the line of the joist or is it better to cut along the side of the joist and then refit after having screwed some 2" x 2" to the joist?
What do you do when you need to lift the board along a wall edge and getting a saw in close is almost impossible?
thanks
pablo2
by pablo2 » Thu Nov 29, 2007 10:06 pm
I think you have answered your own questions there . as you say cutting along a joist watch out for nails and pipes set the saw to 22mm depth and look for pipe runs. As for cuttng near a wall try cutting back a bit further and fix a noggin in through the floor.
Pablo
It is currently Fri Nov 22, 2024 5:12 pm
