shower
joanne gilroy
shower
by joanne gilroy » Fri Dec 21, 2007 4:14 pm
i want to fit a pumped shower system .can i fit the pump under the bath ,connecting to exsisting pipe work to the mixer unit or will i need to have dedicated supplies to the pump plus cylinder flange
marrtin
by marrtin » Sat Dec 22, 2007 12:55 am
You cannot use existing supplies. All mixer showers to function correctly and safely must have dedicated supplies.
A Surrey or ******* flange may be necessary when a pumped shower is fitted, but a close connection to the top of the cylinder is often sufficient. Try first, and if air is drawn in, fit a flange.
You will also almost certainly have to increase the size of your header tank to satisfy the increased requirement of water
marrtin
by marrtin » Sun Dec 23, 2007 12:27 am
I wonder why the word ******* has been deleted from my post as it is the correct term for the part I had in mind.
marrtin
by marrtin » Sun Dec 23, 2007 10:34 pm
E*S*S*E*X
It is currently Fri Dec 27, 2024 7:46 pm
