fitting new electric shower
stripeytom
by stripeytom » Sun Dec 30, 2007 10:11 pm
I am in the process of fitting a new bathroom suite and want to place an electric shower over the bath. I would like some advice on the following:
Is it safe and allowable to take a T-spur off the rising cold water mains feed that goes to the storage tank in the loft, so that I can feed an electric shower?
If I were to use a pumped electric shower can I take a T-spur off the cold water feed to the cold water bath tap? Or should I run a new pipe directly from the storage tank in the loft to feed the pumped shower unit?
Many thanks in advance.
marrtin
by marrtin » Sun Dec 30, 2007 11:35 pm
You can indeed "T" off the rising main for an electric shower, but remember the electrical side to be legal must be made by a qualified sparky.
A mixer shower including a pumped shower must have direct feeds from the header tank and hot water cylinder. You cannot "T" off anywhere along the pipes.
stripeytom
by stripeytom » Mon Dec 31, 2007 8:00 am
Thank you - that is just the confirmation I wanted.
It is currently Sat Dec 28, 2024 9:47 am
