artex wall
rnd
artex wall
by rnd » Tue Jan 08, 2008 12:12 pm
hi all
just wondering how to tackle this one , my mother has just moved into a bungalow with a conservatory , the one wall of the conservatory has artex on it which my mom hate's . Does the artex have to be removed to skim , or can you just board over then skim . or even use a backing coat/browning then skim .
many thank's
rnd
scooty
by scooty » Tue Jan 15, 2008 6:38 pm
hi , im doing the job now . i PVA the artexed walls . when PVA is tacky to touch, plaster coat with carlite bonding to cover artex. Then skim over the bonding.
if you want to skim on the same day then wait untill the bonding coat starts to change colour and then skim. If you skim the next day then put a coat of PVA over the bonding first before skimming.
Hope this helps, good luck
regards Scooty
smuglilal
Re: artex wall
by smuglilal » Tue Jan 15, 2008 6:54 pm
[quote="rnd"]hi all
many thank's
rnd[/quote] i have bonded them over and skimmed before but for best results i would overboard and skim
rnd
by rnd » Wed Jan 16, 2008 11:44 am
many thanks guys , you've been a great help .
It is currently Fri Nov 22, 2024 2:19 am
