by 333rocky333 »
Thu Jan 10, 2008 8:40 pm
If you mean the wire is by the LAMP holder , and that is made of plastic .
You only will need to earth inside one of the holders and the earth may then pick up through out all the metal.
If the earth wire is elsewhere or near the threaded bar you can get an earth tag ,like a washer but with a terminal on it, to fit on the bar and nut up.
Get from a lighting shop and connect the earth on to that.
After check with multimeter continuity from plug earth pin to the metal parts.
Depending how the shade fits, if it has one.
And the way it fits on the metal bar, usually 10mm or 1/2 inch threads are the norm.
you could change the lamp holder's for brass one's with an earth terminal inside it , when connected the earth will then earth the holder , metal bar and the fitting if all are screwed together,but cannot say 100% without seeing it as the existing design may not require earthing.
You can also get plastic " continental lampholders " these have metal thread inside with an earth tag the earth will then earth the metal of the lamp only.
The lampshade fitter is bigger on these though.
May be safer to take to a lighting shop and get done if your in doubt.
