Kitchen Electrics : Powering an Extractor
jamesdv11
by jamesdv11 » Wed Apr 11, 2007 2:05 pm
Hello,
I am currently fitting a new kitchen in my property, Can anyone tell me how I Can power my new chimney type extractor, Can I take a spur from the Cooker Socket into a fused neon 13amp switch then wire the extractor into the that switch, Am on the right lines?
I also would like to add under wall cupboard lighting, would this be the same procedere, spur from a lightswitch into a fused switch then connect the strip lights?
Appreciate the help
James
Jeffmo
by Jeffmo » Wed Apr 11, 2007 11:11 pm
Your electrician who should be the one doing the work is the best person to ask . Unless your part p self certified you aint suppossed to be touching it legally . Sorry for the downer Regards Jeff
by sparx » Wed Apr 11, 2007 11:29 pm
you are not allowed to do any wiring in a kitchen yourself you are breaking the law!
see part p in projects
it is not permitted to take any other load from a cooker point anyway,
your registered electrician can install fused connection units from a socket to fuse down for extractor and lights, you can't feed anything from the light switch as there will not normally be a neutral there.
regards , Sparx
jamesdv11
by jamesdv11 » Thu Apr 12, 2007 1:41 am
Thanks! Thats Told me! I shall get my resident electrician in!
It is currently Wed Jun 26, 2024 10:36 am
