plumbing
muldave65
plumbing
by muldave65 » Fri Jan 25, 2008 4:44 pm
if i use pushfit fittings connected to copper surely i dont need to earth clamp them
bobplum
by bobplum » Fri Jan 25, 2008 8:28 pm
ive not got the water regs book at hand but there is a belive that the clamping ring(metal) inside the pushfit may act as a conductor for the two copper sections either side
for the small cost is it worth not doing
cyclop.orangehome.co.uk
Pushfit earth conns.A
by cyclop.orangehome.co.uk » Tue Jan 29, 2008 8:44 pm
As there is no electrical path through a plastic pushfit fitting,even with copper either side, you will have to bridge the fitting with earth clamps.
It is currently Tue Nov 26, 2024 11:58 am
