Dripping overflow
Lawrence
Dripping overflow
by Lawrence » Sun Jan 27, 2008 4:29 pm
Hi - Recently my overflow from the F&E tank has started dripping. The water level in the tank is well below the overflow level. Is this normal? Presumably it is just condensation.
Is there anything I can do to stop the dripping?
thanks
cyclop.orangehome.co.uk
dripping o/flow
by cyclop.orangehome.co.uk » Tue Jan 29, 2008 8:18 pm
look in your tank first thing in the morning before anyone uses hot water.Is the level higher than normal? Is the overflow pipe dripping?If the answer to either of these questions is yes then look at the ball valve.[Condensation is an unlikely cause.]
garom
by garom » Thu Feb 07, 2008 3:40 am
Can some one please advise my expansion tank is overflowing is this a valve problem ? or something more as there seems to be water coming from the swan neck shaped pipe?
It is currently Tue Nov 26, 2024 3:49 pm
