bathroom mirror light wiring
Dave B
by Dave B » Mon Feb 11, 2008 1:15 am
I have purchaced a new bathroom mirror wall cupboard which has a light fitted. The associated transformer has a 2 core flex cable. what type of connector do I need to connect it to the house cabling comming from the wall. Should I use a "clock" socket or can I just use one of those terminal block connectors which are contained in a plastic box? The connection will be behind the cupboard.
by ericmark » Mon Feb 11, 2008 4:15 pm
Bathroom regulations are very tight. Where are you fitting it?
Dave B
by Dave B » Mon Feb 11, 2008 8:58 pm
I am fitting it on a wall in zone 3.
by ericmark » Tue Feb 12, 2008 8:08 am
Oh here we go again no Zone 3 in new book, if more than 3 meters from bath no problem but all work in bathrooms comes under Part P and not really a diy job. No plugs or sockets allowed closer than 3 meters so will need spur unit any closer and has to be permanently wired in. Which is why it has no plug.
Dave B
by Dave B » Wed Feb 13, 2008 1:00 am
Thanks ericmark. I'm having my bathroom completely re-vamped so I am just getting as much info as possible beforehand to prepare for when the men move in so the job can be done as quickly as possible - I can only cross my legs for so long. By the way when I said "clock socket" I meant one of the wall mounted plates with a flexible cord comming from it rather than just a connextion box. I'll leave the actual connecting to the sparks though I had rewired my old house back in the70's but I know regs have changed.
It is currently Thu Jan 16, 2025 10:03 am
