interior conservatory doors
mikehearnden
by mikehearnden » Wed Feb 13, 2008 5:58 pm
I am hoping to make my dining room and upvc conservatory open plan. I have taken the door of but can not work out how to remove the rest of the frame. I cant see any fixings. Please help. thanks
ALDA
by ALDA » Wed Feb 13, 2008 11:04 pm
I ASSUME THE DOOR FRAME IS WOOD IN AN EXTERIOR BRICK WALL!
DOOR FRAMES IN OLDER PROPERTIES ARE NAILED THROUGH INTO WEDGES OF WOOD IN MORTAR JOINTS OF BRICKWORK.
IF YOU HAVE NEWER PROPERTY, THE FRAME MAY WELL BE SCREWED TO THE BRICKWORK.
IF DOOR FRAME IS IN TIMBER STUD WALL, THEN IT WILL BE EITHER NAILED OR SCREWED.
IF YOU WISH TO REMOVE FRAME WITH CARE , THEN LOACATE NAILS/SCREWS WITH METAL DETECTION DEVICE.
IF YOUR NOT BOTHERED ABOUT DAMAGE TO WALLS, THEN JUST LEVER OFF WITH CROWBAR OR SIMILAR LEAVERS.
mikehearnden
Interior Conservatory door
by mikehearnden » Thu Feb 14, 2008 4:26 pm
Many thanks for your reply. The door is on the exterior wall but is in upvc. I still cant locate any fixings, and will need to preserve wall and door if possible. Thanks
It is currently Sun Dec 22, 2024 12:01 pm
