Energy Saving
ElectricVirgin
Energy Saving
by ElectricVirgin » Wed Feb 13, 2008 8:22 pm
Any ideas on ways of saving electricity and I dont mean by turning everything of all the time!
333rocky333
by 333rocky333 » Thu Feb 14, 2008 6:54 pm
Power Factor correction
ross.earn
by ross.earn » Fri Feb 15, 2008 8:28 am
Interested in this possiblity.Would power factor correction apply to a home with only frig and oil burner motors ?
by ericmark » Fri Feb 15, 2008 1:22 pm
Discharge lights, motors, etc. will caused a shift from unity but in the main any correction on a small scale is done within the unit. So within the home unlikely to affect us. Although on an experiment with florescence lamps removing the capacitor could change power use from 66 watt to 132 watt and this was for a 60 watt unit. As you can see even with the capacitor it was using over the ratted value. For 25 units it was using 2.2Kw instead of 1.5Kw all because it was slightly over voltage. Using HF (High Frequency) units will cure this problem plus prevent stroboscopic effect make tubes last longer and retain there light output longer. But how many florescence units do we use in the home. Cathode ray tubes also use a lot of power and LCD units must be a big saving. Where there is some warm-up or inrush i.e. TV's one has to be careful not to switch off for short time as it uses more to restart than is saved by switching off.
333rocky333
by 333rocky333 » Fri Feb 15, 2008 4:40 pm
Only ever seen it in commercial shops with high levels of inductive lighting loads , large capacitor banks switch in and out to bring back to nigh on unity power factor
On a smaller scale may not be economically viable,but there may be a smaller similar system available.
Most lighting manufacturers now fit a capacitor across the supply internal to there fittings now.
It is currently Mon Nov 25, 2024 2:29 am
