Internal Soil Stack
paco
Internal Soil Stack
by paco » Thu Mar 06, 2008 8:32 pm
We have had a conservatory built and they have left the soil stack inspection chamber man hole inside the conservatory this has caused a smell to continually come from the manhole, we asked a drain person to look at it and he has said that the internal soil stack is capped and so the smell is caused by it being unable to vent. We are in a new build house, if the manhole is sealed and moved into the garden will this resolve the smell issue and how does the stack vent smells and gasses away from the house without a vent on in the first place.
Can moving it interfere with removal of gasses and smells and will this resolve it?
I am confused as to how this works?
ALDA
by ALDA » Thu Mar 06, 2008 11:07 pm
PACO,
THE INSTALLER OF YOUR CONSERVATORY SHOULD NOT HAVE SHORTENED AND CAPPED THE SOIL STACK.
THIS PIPE IS THERE TO CHANNEL SEWAGE WASTE TO DRAINS AND VENTILATE POTENTIALLY DANGEROUS SEWER GASES AND ODOURS INTO THE AIR ABOVE ROOF LEVEL.
THE SOIL STACK NEEDS TO BE ROUTED THROUGH THE CONSERVATORY ROOF AND A GOOD SEAL PROVIDED TO PREVENT RAINWATER PASSING INTO CONSERVATORY ROOF.
(THIS IS PROBABLY WHY YOUR INSTALLER SHORTENED AND CAPPED THE SOILSTACK IN THE FIRST PLACE TO MAKE CONSERVATORY INSTALLATION EASIER. â€
It is currently Mon Jan 06, 2025 11:35 am
