Tiling on to plywood?
prbaxter
by prbaxter » Sat Mar 15, 2008 2:38 pm
I've just read numerous plywood related tiling posts, and still i'm a bit confused, hence this post.
Simple question.
Can I tile directly on to 12mm plywood?
Can I also point out, that the area of plywood is about 11inches square, covering an old airvent hole, and will also have an electric extractor fan covering most of the centre, so i'm really only tiling round the edges.
Ta,
Baxt
rosebery
Re: Tiling on to plywood?
by rosebery » Tue Mar 25, 2008 7:19 pm
"Can I tile directly on to 12mm plywood?"
Yes but prime it with an acrylic primer first.
".........................Im really only tiling round the edges."
Doesn't matter
"Ta"
De rien.
prbaxter
by prbaxter » Fri Jan 09, 2009 9:56 am
i coated the 12 inch square ply with PVC.
then tiled over it.
sorted.
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:58 am
It is currently Fri Nov 22, 2024 12:10 am
