by DONFRAMAC »
Tue Mar 18, 2008 1:20 am
The company which produces "SALAMANDER" brand cleansers and inhibitors, offer a testing service for your anti-corrosion strength, so you can top-up as needed.
The steel your radiators are made of reacts with water to produce a magnetic type of iron oxide called magnetite. There is a product on the market which removes this, trapping it on the surfafe of a permanent magnet in a pot. This "MAGNACLEAN" brand unit is fitted with isolator valves, so that you can shut-off the CH., then take the magnet out for a good clean under running water. (price is about £100)
Sealed CH systems are much less prone to black-sludge, so long as topping-up has been minimal.
