Mirror as a fireplace back panel?
Arbies
by Arbies » Mon Mar 24, 2008 9:43 am
Hi there. I am in the process of making a unique fireplace. I want to use mirror as a back panel but am not sure if this is safe.
The house was built in 1987 so no chimney, basically it is just a plasterboard wall.
I have bought a flueless gas stove that will sit on the floor but to keep the light in I really want a reflective surface, hence mirror.
Will this be suitable?
Thanks for reading!
winger
by winger » Mon Mar 24, 2008 9:11 pm
Doesnt sound too bad an idea as long as it doesn't get too hot (try not to fit the mirror too close). Also i would recommend you use a 6mm thick mirror. It might be worth getting an off cut of mirror and just plonk behind and see if it it is going to work without it cracking, but i think it should be fine.
Arbies
by Arbies » Tue Mar 25, 2008 12:43 pm
Great idea, thanks for that!
It is currently Sat Sep 21, 2024 6:03 pm
