tv aerial
stronach
tv aerial
by stronach » Thu Sep 04, 2008 1:08 pm
Doesn't seem to be many tv related queries in this section but hope someone can help. I am planning to put a small lcd tv in our kitchen, I was going to run an aerial lead off the aerial in my loft which serves the tv in my daughters bedroom, she gets a good picture off this aerial using a freeview box. The tv in our lounge is connected to an outside wall mounted aerial. If I connect the proposed kitchen tv to the loft aerial with a splitter connector will the signal quality be reduced to both tv's or will it not be affected.
TheDoctor4
by TheDoctor4 » Thu Sep 04, 2008 4:45 pm
Have you had a look at the DIY projects. There is one relating to Tv arials and coaxial cables: https://www.diydoctor.org.uk/projects.htm. Alternatively you may want to try posting in the Home Automation & Cinema forum: https://www.diydoctor.org.uk/forums/viewforum.php?f=190 If you receive no answers in this forum
Regards
plumbbob
by plumbbob » Fri Sep 05, 2008 11:04 pm
If you use just a simple "Y" splitter, the signal to each television will be halved. If you are in a strong signal area with a good ariel, then the signal may still be sufficient to supply both sets. Having said that, the Freeview broadcasts require a strong signal, so this may not work - try it.
If this fails, and you don't want to fit another ariel, use a amplifier / splitter installed in the loft. The downside here is they require a power supply.
stronach
tv aerial
by stronach » Sat Sep 06, 2008 12:18 pm
Thanks for the advice, much appreciated.
stronach
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 9:57 am
It is currently Sun Dec 29, 2024 10:35 pm
