1) I'm changing a light fitting. At the moment its a normal pendant light with three cables going to it, two small cables (about 8mm wide) one larger cable (about 10mm wide). They are all connected within the rose. The new light is very different. It has a decent sized earth but only very small push-in type live and neutral terminals (one each). There is easy access to the roof space above the light. I can see that the wider cable goes to the switch, one of the smaller cables goes to another light, the other disappears into the wall and heads down. How do I fit all the wires that are going to the original light into the new one?
2) I'm also swapping my electric shower. It has 6mm cable. What is the maximum kW output I can run on this size cable?
Many thanks in advance
Oz
