upvc cladding
Carnegie
upvc cladding
by Carnegie » Thu Jun 11, 2009 3:47 pm
I want to install white horizontal upvc shiplap cladding (from Wickes) on several south facing areas of a residential building, to improve general appearance & reduce maintenance. Currently, the areas are covered by painted plywood sheets fixed to battens. Firstly, can I fix the cladding direct onto the plywood (using the standard upvc bottom, side & top fixings) and if so, do I need to put a vapour/damp proof membrane on top of the plywood, as a precaution. Finally, someone suggested the cheaper option was to install hollow tongue & grooved soffit boards instead of the shiplap cladding. Any help or advice would be appreciated
TheDoctor4
Local help at hand!
by TheDoctor4 » Fri Jul 09, 2010 9:55 pm
Find trusted, insured and vetted tradesman local to your area. Visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Thu Jan 09, 2025 12:49 pm
