UPVC Door dead bolt just goes into upvc frame with no latch
Hfighs
by Hfighs » Tue Jan 11, 2022 1:23 pm
https://ibb.co/m6dRVyg
https://ibb.co/F4FQR3M
Noticed a draft on my front door for a while so I thought I’d check the latches out and I discovered that the deadbolt just goes directly into the upvc frame and doesn’t have a latch over it, is this normal ?
Included some pics, if I was to get a new latch what kind would I get ? The door frame seems a bit like an odd one
Re: UPVC Door dead bolt just goes into upvc frame with no latch have sufficient
by stoneyboy » Wed Jan 12, 2022 10:33 pm
Hi hfighs,
If you can depress the door handle when the door is locked then you need to get a keep plate to reinforce the deadlock cut out. If the handle does not depress when the door is locked you probably have sufficient security from the latch.
It is currently Thu Apr 17, 2025 10:59 pm
