I have recently refurbished my bathroom and problem arise, just wonder anyone here maybe able to get me some advice.
I have a indirect system in my flat. Basically, the cold water from the main feed the water tank and the water tank feed the hotwater cyclinder.
Because of low water pressure, I installed a shower pump. The cold input to the pump is from the water tank, and the hot water input is from the hot water cyclinder. The pump is working but, once I have the shower turn on for about 2-3 minutes, the water pressure drop down, and I have to turn off the shower for few second and turn it back again in order to get water presssure work properly again. Can anyone here know what is the problem ???
My next problem is the cold water pressure to my basin. The basin mixer tap cold inlet is direct from the water tank and hot inlet is from the cyclinder.
It work ok before the pump was installed. Now, even the pump/shower is turn off, the hot water work ok but the cold water is lower than we have before. The hot/cold supply to the mixer tap have nothing to do with the shower pump, it is exactly the same connection as before. The shower pump only connected for the shower, I don;t know why this doesn't work properly.
Please, I need help..
Many thanks.
