Using Speedfit question
skirkpat
by skirkpat » Tue Jan 22, 2008 9:14 pm
I'm trying to install a washing machine, but a 15mm copper pipe (cold water supply to kitchen tap) is in the way & needs to be moved. I heard Speedfit adaptors can be used directly on the copper pipes with a Speedfit flexible pipe. I'm looking at getting the following:
http://www.awin1.com/pclick.php?p=14400 ... 071&m=1228
If this is the correct hose to use, what adaptor would I need to connect this onto a copper pipe without fuss? Also, is there anything to bear in mind when doing this? Any potential probs etc..?
Thanks in advance for any advice :D
It is currently Wed Feb 05, 2025 6:08 pm
