Vailant turbomax boiler water not as hot as it was
Lbox
by Lbox » Tue Nov 09, 2021 3:53 am
Our 20 yr old boiler has been serviced every 2-3 years since installation but has recently been providing less than pipping hot water even with the water control knob turned upto no9 (max) (Iirc I turned the water temp upto max a couple of years ago now..)
I have not had much luck with the local plumbers i have delt with recently (mira shower needed a £150 cartridge replacement a 10 minute diy job, I had 2 quotes to fix by ripping out of the wall and replacing before i went diy .)
I suspect the plate heat exchanger in the boiler has started to choke up with calcium deposits? it is quite a hard water area here. and its been in place for 20 years.
Is this a likely scenario?
If so what would be a reasonable charge for a plumber to install?
Is it a diy-able job.. I did download the service manual about a decade back when a pressure switch needed replacing and managed that simple part exchange but that did not require any removal of elements to enable access..
Thanks in advance for all and any help..
It is currently Mon Jan 20, 2025 4:38 pm
