by Barbastelle »
Tue May 04, 2021 2:56 am
First off. Find your Users manual, or download it from the internet at Vaillant web site but not from other web sites that will charge you.
Along with it you will need the service manual. You will not be touching the gas side so do not worry.
Under the boiler you will find two 1/4 tern taps. These are used to turn on the water (from the mains) to fill your radiators. It is important to turn them to the correct positions once you are finished. The water in the rads. will be pressurised to about one to one and a half Bar. when cold. So the pressure will need to be set watching the graph on the LCD display. Too a low pressure the boiler will cut out, not start. Boiler will have a MagClean fitted as required for the boiler guarantee. Also inhibitor in the water of the radiators. Be sure to understand your Consumer rights Act 2015. It lasts longer than the guarantee.
Good luck regards Barbastelle
