The boiler as the following problem hope an expert can help me.
I turn the room thermostat to click (23degrees) & the boiler fires up. The temp dial on the boiler hovers around 60degrees for aprox 10Mins, flicking between hi/low flame. The flame then stays on high all the way from 60-88 degrees then the boiler switches back to a low flame & the boiler temp indicator keeps falling all the way back down to 60ish. During this falling temp period the flame doesn't go high again not even once. Only when i move the room thermostat to a higher temp it kicks back to hi flame but this time the boiler temp indicator rises to 100+ degrees – I then manually switch the boiler off to be safe.
I managed to get an identical boiler off ebay to use as a spare & have since swapped the NTC resistor but still overheating.
I've been told that it could be the room thermostat (must admit it's quite old) or the swapped ntc could also be faulty (i think small chance having exactly same ntc fault).
Anyone any ideas? I know it's a long read but am desperate to get this sorted so have put as much info in as possible.
