Valves???
the2ems
Valves???
by the2ems » Fri Nov 21, 2008 9:59 am
Can someone please explain the difference between an isolating valve and a service valve. Which one should I use for an electric shower, and are the speedfit ones suitable? Thanks
plumbbob
by plumbbob » Fri Nov 21, 2008 7:49 pm
In principle, they serve the same purpose, but what is usually referred to as a service valve is a small inconspicuous valve that is turned on and off with a screwdriver and an isolator is a larger valve with a handle (either a gate valve or stop tap).
Electric showers can use either a stop tap or service vale.
http://www.awin1.com/awclick.php?mid=12 ... Cocks-15mm
http://www.awin1.com/awclick.php?mid=12 ... -Pack-of-5
Steve the gas
by Steve the gas » Sat Nov 22, 2008 6:49 am
They are the same thing, yes if its for a shower it will be fine if its a full flow valve.
Hth
the2ems
by the2ems » Sat Nov 22, 2008 3:59 pm
Thanks for the replies. :D
chris_on_tour2002
by chris_on_tour2002 » Sun Nov 23, 2008 6:25 pm
use a full-bore isolator valve (the handle type) as this will give a better flow rate to the shower.
It is currently Sun Aug 09, 2026 11:29 pm
