Vibrating valve and low water pressure
max101
by max101 » Tue May 25, 2010 8:05 pm
We have a mains pressue hot water system (Ariston) which worked brilliantly when we first moved in. We could run a bath and shower at the same time no problem.
Then my partner accidently put the wrong salt into the water softener (flakes instead of cubes), and the 3 way valve (with the strainer on it) starts to vibrate every time we flush the loo. The hot water pressure has also gradually dropped.
Do you think the valve needs replacing?
Thank you!
Max
It is currently Fri Jan 10, 2025 10:56 pm
