Concealed Hinges_ holes
amato
by amato » Fri Aug 24, 2007 8:18 am
what is the distance from the edge of the hole and the edge of the panel ( a-c edge) assuming you need to make holes to fit 26mm or 35mm concealed hinges?
Oddbod
by Oddbod » Wed Aug 29, 2007 5:37 pm
Hi. It can vary depending on what you need to do. For the 35mm hinges I’d go for 23mm from edge to centre of hole. Unless you have a really odd situation I suspect that’ll work. I don’t remember the figure for the other size hinges off the top of my head. Sorry.
Most manufacturers have a data sheet, which is probably on their website. I have an old woodfit (google them) catalogue which has all the measurements in, and which I refer to when necessary.
When in doubt, make a mock up!
It is currently Sun Dec 29, 2024 2:03 pm
