Newbie building simple frame, trying to keep it square
MJ76
by MJ76 » Wed Aug 23, 2023 11:37 am
Hi folks, hopefully an easy question for someone with some knowledge can help me with. Im building a wood frame which I intend on using as a log store roof which will be covered in felt. My main question is simply that I seem to struggle with constructing frames that dont flex out of being square. That is to say, ive got 4 bits of wood (the outer frame) which im fixing together with butt joints. I appreciate butt joints arent the strongest, but how do I make the frame more rigid so that it doesnt flex out of being 'square'. Ive consructed the frame so far and it is square, with 2 screws at each point of fixing. Ive purchased some 90 degree corner clamps which will hopefully help me build in future. For this frame, should I insert square peices of wood in each corner and screw in from each side? Obviously looking for a straight forward option with minimal intricacy. Thank you =)
Re: Newbie building simple frame, trying to keep it square
by stoneyboy » Fri Aug 25, 2023 9:56 pm
Hi mj76,
Cut yourself some 300mm (ish) lengths of the frame timber with 45deg cuts on both ends screw and glue these inside the corners of your frame.
It is currently Fri Dec 27, 2024 6:45 am
