Repair wood window section
TimM
by TimM » Sat Jan 06, 2024 11:15 am
Hi, my first post on here!
I have a couple of wooden window frames which need to be repaired. The bit in question is the corner of the opening window at the bottom. I was thinking of cutting out and refitting with hardwood, paint and preserve. I am on the right lines with this?
Many thanks for any advice.
Tim.
Re: Repair wood window section
by stoneyboy » Sun Jan 07, 2024 11:14 pm
Hi timm,
Depends on the extent of the rot, if it’s in most of the corner joints you may as well replace the whole lower section.
TimM
by TimM » Mon Jan 08, 2024 11:34 am
Thank you, I may well do that! Thanks again, Tim.
It is currently Sun Nov 03, 2024 12:00 pm
